 by Carl-SolderSplash » Wed Oct 16, 2013 10:17 pm
			Thanks Helmut,
I have made the changes and updated the github repository. Sorry for the mistakes, I completed it in a bit of a rush, glad you picked up on them so quickly.
PIN 7 is now ground on all DipCortex's, it was N/C on the pre-production run we did, will need to update the DipCortex Diagram.
DipCortex uses a MIC5225-3.3YM5 which has a 2.3v to 16v input range, but the input voltage is tied directly to the processors VBUS line so you are limited by input range on this pin. which typically expects 5V's. Would need to look at the LPC datasheet to check min/max voltages.
The WiFi DipCortex uses a different regulator due to the CC3000 power requirements when transmitting and this has a 6V max input.
For externally powering the Dips from a higher voltage external regulation down to 5v or 3.3v is my current suggestion. It would be nice to allow wide range input if we can find a simple very low component count method of doing it.
We are thinking of making a Lipo baseboard to demonstrate battery powering a Dip, we could add a wide range input to that as well, perhaps.
Shall consider the suggestions once we are ready for the next batch.
Thanks again!
