wifi.connect_non_blocking need to be called twice
Posted:
Sat Jun 14, 2014 10:06 pm
by peter247
I`m trying to make a web socket server with the wifi dipcortex , and found it I could not get it to connect if you just use "wifi.connect_non_blocking((uint8_t *)SSID, (uint8_t *)AP_KEY, AP_SECURITY);" once , but you use the command twice it works .
eg
it connect a couple of seconds later !!!!
any documentation on how to make a socket server , eg now to listen to a port , receive to incoming tcp connection ?
Re: wifi.connect_non_blocking need to be called twice
Posted:
Sun Jun 15, 2014 10:49 am
by Carl-SolderSplash
Thats a bit strange, I use wifi.connect_non_blockingin the kitchensink project.
http://mbed.org/teams/Solder-Splash/cod ... tchenSink/The connection can take a few seconds to get setup. To check the connection once you have called connect :
- Code: Select all
if (( wifi.is_enabled() ) && ( wifi.is_dhcp_configured() ))
wifi.get_ip_config(&ipinfo);
The Kitchensink demo has both websocket transmit and receieve ( WebSocketReadTest() in tcpTest.cpp )
Posted:
Sun Jun 15, 2014 12:53 pm
by peter247
I`m using the kitchensink project , but I`ve removed the menu system and cut it down to just main.cpp.- Code: Select all
#include "mbed.h"
#include "cc3000.h"
#include "TCPSocketConnection.h"
#include "TCPSocketServer.h"
#include "wifi.h"
#include "UDPSocket.h"
#include "main.h"
#include "NTPClient.h"
#include <time.h>
#define slave_address 0x44
using namespace mbed_cc3000;
/* cc3000 module declaration specific for user's board. Check also init() */
#if (MY_BOARD == WIGO)
cc3000 wifi(PTA16, PTA13, PTD0, SPI(PTD2, PTD3, PTC5), PORTA_IRQn);
#elif (MY_BOARD == WIFI_DIPCORTEX)
cc3000 wifi(p28, p27, p30, SPI(p21, p14, p37));
//Serial uart(p19, p20);
I2CSlave slave(p23, p18); // sda , sclk
Serial RFID( p25 , p26 ); // tx , rx
DigitalOut rfid_rst(p24);
#endif
bool Connected = false;
bool UsingSmartConfig = false;
char _deviceName[] = "CC3000";
tNetappIpconfigRetArgs ipinfo;
extern char tmpBuffer[512];
char fob_status = 0 ; // 0 = clear , 1 = new fob , 2 = old fob
char last_fob[20];
int cnt = 0;
int reg = 0;
int data = 0;
int i;
char tmp_char;
@brief main loop
int main( void )
init();
RFID.baud( 9600 );
wifi.start(0);
rfid_rst = 0;
wait ( 1 );
rfid_rst = 1;
setup_wifi();
slave.address( slave_address );
while (1)
check_rfid();
check_wifi();
i = slave.receive();
switch (i)
case I2CSlave::ReadAddressed:
if ( reg == 0 )
slave.write( fob_status );
else if ( reg == 1 )
slave.write( last_fob , 13 );
else if ( reg == 3 )
slave.write( Connected );
else if ( reg == 123 )
slave.write( "v1.1c" , 6 );
slave.stop();
break;
case I2CSlave::WriteAddressed:
reg = slave.read();
if ( reg == 2 )
fob_status = 0;
wait_us(10);
slave.stop();
break;
void init()
NVIC_SetPriority(SSP1_IRQn, 0x0);
NVIC_SetPriority(PIN_INT0_IRQn, 0x1);
// SysTick set to lower priority than Wi-Fi SPI bus interrupt
NVIC_SetPriority(SysTick_IRQn, 0x2);
// Enable RAM1
LPC_SYSCON->SYSAHBCLKCTRL |= (0x1 << 26);
void check_rfid( void )
while ( RFID.readable() > 0 )
tmp_char = RFID.getc();
if ( tmp_char == 2 )
cnt = 0; // start number = 2
else if ( tmp_char == 3 )
fob_status = 1; // end number = 3
else
last_fob[cnt] = tmp_char;
cnt++;
void check_wifi(void)
if ( wifi.is_connected() )
Connected = true;
else
Connected = false;
void setup_wifi(void)
uint32_t ip = 0;
// Enable DHCP
wifi._netapp.dhcp(&ip, &ip, &ip, &ip);
RFID.printf("\r\n Connecting to : %s key : %s", SSID, AP_KEY );
wait( .5 );
while ( !wifi.is_connected() )
wait(0.1);
print_cc3000_info();
TCPSocketServer server;
TCPSocketConnection client;
server.bind(80);
server.listen();
while ( server.accept(client) == 0 )
wait(0.1);
RFID.printf("waiting");
client.set_blocking(true); // Timeout after (1.5)s
RFID.printf("Connection from: %s \r\n", client.get_address());
client.close();
server.close();
void print_cc3000_info() {
uint8_t myMAC[8];
uint8_t buffer[2];
int32_t status = 0;
tNetappIpconfigRetArgs ipinfo2;
tUserFS cc_user_info;
const char * WIFI_STATUS[] = {"Disconnected", "Scanning", "Connecting", "Connected"};
wifi.get_user_file_info((uint8_t *)&cc_user_info, sizeof(cc_user_info));
wifi.get_mac_address(myMAC);
RFID.printf(" MAC address : %02x:%02x:%02x:%02x:%02x:%02x\r\n", myMAC[0], myMAC[1], myMAC[2], myMAC[3], myMAC[4], myMAC[5]);
if (! wifi._nvmem.read_sp_version( (unsigned char*)&buffer ) )
RFID.printf(" CC3000 Firmware Version : %u.%u \r\n", buffer[0], buffer[1]);
else
RFID.printf(" CC3000 Read nvmem failed!");
status = wifi._wlan.ioctl_statusget();
if (( status > -1 ) && ( status < 4 ))
RFID.printf(" Wifi Status : %s\r\n", WIFI_STATUS[status]);
else
RFID.printf(" Wifi Status : %d\r\n", status);
if ( wifi.is_dhcp_configured() )
wifi.get_ip_config(&ipinfo2);
RFID.printf(" Connected to : %s \r\n", ipinfo2.uaSSID);
RFID.printf(" IP : %d.%d.%d.%d \r\n", ipinfo2.aucIP[3], ipinfo2.aucIP[2], ipinfo2.aucIP[1], ipinfo2.aucIP[0]);
RFID.printf(" Gateway : %d.%d.%d.%d \r\n", ipinfo2.aucDefaultGateway[3], ipinfo2.aucDefaultGateway[2], ipinfo2.aucDefaultGateway[1], ipinfo2.aucDefaultGateway[0]);
RFID.printf(" Subnet : %d.%d.%d.%d \r\n", ipinfo2.aucSubnetMask[3], ipinfo2.aucSubnetMask[2], ipinfo2.aucSubnetMask[1], ipinfo2.aucSubnetMask[0]);
RFID.printf(" DNS : %d.%d.%d.%d \r\n", ipinfo2.aucDNSServer[3], ipinfo2.aucDNSServer[2], ipinfo2.aucDNSServer[1], ipinfo2.aucDNSServer[0]);
RFID.printf(" Cached IP : %s \r\n", wifi.getIPAddress());
RFID.printf(" Cached Gateway : %s \r\n", wifi.getGateway());
RFID.printf(" Cached Subnet : %s \r\n", wifi.getNetworkMask());
else
RFID.printf(" Not connected \r\n");
Looks like I may have to start again and work on just getting the wifi and tcp socket server working and add the other bit after.
I copied the rough ideas from your code , but for me it`s not waiting for a connection .
re - tcp server problems
Posted:
Mon Jun 16, 2014 2:01 pm
by peter247
FIXED !!!!!
I had a misunderstanding of how server.accept(client) and client.set_blocking(false, 1500); work.
I had the idea that the code should wait after server.accept() for a incoming connection , but looking at it that would be catch 22 , because you would have to accept a incoming connection to use make it blocking with client.set_blocking.
So what I need to do is say server.accept() = -1 no connection and server.accept() = 0 , someone has connected ..
Posted:
Tue Jun 17, 2014 11:38 pm
Awesome, thanks for letting us know. I'm sure it will help others too.
