Hi everybody,
in my project I want to use the wireless channel as a source of entropy. Therefore I need to get the received signal strength indicator (RSSI).
How do I get the RSSI? (I want to avoid changing the CC3000 driver)
Thanks a lot
typedef struct Result_Struct
uint32_t num_networks;
uint32_t scan_status;
uint8_t valid:1; // Note : this works in LpcXpresso, but structure packing depends on the compiler!, valid bit is bit0 LSB
uint8_t rssiByte:7;
uint8_t Sec_ssidLen;
uint16_t time;
uint8_t ssid_name[32];
uint8_t bssid[6];
} ResultStruct_t;Users browsing this forum: Google [Bot] and 23 guests
