WiFiDip-KitchenSink using GCC
Hi Guys,
are you able to give some guidance on compiling the WiFiDip-KitchenSink mbed example using GCC 4.7.2?
I am currently seeing this error using Netbeans.......
Is GCC 4.8 required? Do you have an example HelloWorld project for the WiFiDipcortex platform that can be compiled offline?
Thanks,
Chris
d:/yagarto-20121222/lib/gcc/../../arm-none-eabi/include/c++/4.7.2/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
In file included from main.cpp:7:0:cc3000_hostdriver_mbedsocket/socket/UDPSocket.h:66:17: fatal error: def.h: No such file or directory
compilation terminated.
Thanks,
Chris
