WiFi DipCortex LPCXpresso Example Code - Serial Terminal
Postby Carl-SolderSplash » Sun Aug 11, 2013 9:12 pm
Re: WiFi DipCortex Example Code Serial Terminal
Postby Carl-SolderSplash » Wed Oct 30, 2013 10:16 pm
To get you started here is our example firmware for the WiFi DipCortex.
https://github.com/SolderSplashLabs/WiFi-DipCortex/
This gives you control of the CC3000MOD over USB CDC (Serial). We will continue to work and add features/examples to this over time.
To use the USB CDC (Serial) port you will need to install the driver that can be found here
Postby Carl-SolderSplash » Wed Oct 30, 2013 10:21 pm
Here is a list of the terminal commands :
Display menu of available commands
Get IP Config of the connection
>ipconfig
MAC : 08-00-28-57-38-C2
IP : 192.168.0.26
Gateway : 192.168.0.1
DNS : 194.168.4.100
Subnet : 255.255.255.0
List all IP's of cached hostnames
>ipconfig dns
0.pool.ntp.org - IP 206.51.211.152 - Seconds old 175
Flush the DNS cache
>ipconfig flush
Set CC3000 module to dynamic IP using DHCP
>ipconfig dynamic
Set manual IP address - IP, Gateway, Subnet, DNS
>ipconfig 192.168.0.69 192.168.0.1 255.255.255.0 8.8.8.8
Connect to a previous access point saved in the CC3000's eeprom
>connect
Connect to a new access point - access point name, encryption type, password
>connect myacccesspoint 3 letmein
0 = Unsecured, 1 = WEP, 2=WPA and 3 = WPA2, note this example doesn't like AP names or keys with spaces
Disconnect
>disconnect
Query the module status, this reports the firmware revision and internal CC3000 status. Version 1.24 is the latest TI firmware revision
>status
Asking for current Wifi status
HCI Event Received : 0x0009 - Status Req
Wifi Status Returned : Connected
HCI Event Received : 0x0207
Version : 1.24
Resolve a hostname to an IP using built in CC3000 function and DNS cache
>resolve www.google.com
resolve a hostname manually bypassing CC3000
>resolve now www.google.com
Get current cached time and date
>time
Update time and date from the internet using NTP
>time update
Get the uptime of the module
>time update
HTTP, these functions are very rough and non compliant to HTML specs, but provide a demonstration of opening a TCP port and sending/receiving data
http get
>http get www.google.com
http set api key
http api API_KEY_HERE
http put example, sends dummy data to the supplied URL with the API key
>http put api.xively.com /v2/feeds/FEEDNO.csv
Read the two GPIO ports of the processor
>gpio
CC3000 start smart connect, this allows you to configure the accesspoint connection details with an iOS or android device
>cc3000 smart
CC3000 set connection policy manually- use the values 0 or 1 only - connect to open AP, connect to last AP, connect to stored AP
>cc3000 policy 0 0 1
CC3000 mdns (Note TI mdns functionality seems a bit buggy currently) - 1=enable 0=disable
>cc3000 mdns 1
CC3000 re-initalise - mode 0/1 0 is normal mode and 1 is patching mode
>cc3000 init 0
CC3000 delete stored profiles
>cc3000 delete
Users browsing this forum: Majestic-12 [Bot] and 20 guests
