External Power Problem
Postby wpfundstein » Tue Nov 04, 2014 12:58 pm
1. if i use a powersupply with micro usb on the wifi-dipcortex it does not work. it powered up only if i connect the USB cable to my pc.
2. if i use external power on pin 32 (+5V) und pin 31 (GND) the module also does not powered on. if i connect external power on this pins i have 3.3 V on pin p11. so i think the regulator works.
any ideas?
wpfundstein
Re: External Power Problem
Postby Carl-SolderSplash » Tue Nov 04, 2014 1:42 pm
If you can measure 3.3v on the 3.3v pin when you apply 5v the regulator is working and so should the processor.
I would eliminate the software, use a simply blinky application to just flash the led to show the micro is running.
The USB vbus is the 5v net so there should be no electrical difference
Postby wpfundstein » Tue Nov 04, 2014 3:10 pm
Grazy. After removing the lib USBDevice it works.
wpfundstein
Users browsing this forum: Majestic-12 [Bot] and 10 guests
