CC3000 Pins
CC3000 Pins
Postby bonitusb » Sat Aug 09, 2014 1:53 pm
PIO1_15 --> CC3000 - Output - Vbat Enable - CC Module powered when high
PIO1_16 <-- CC3000 - Input - IRQ - Raised when CC wants to be talked too
PIO1_19 --> CC3000 - Output - CS - Active low
PIO1_20 --> CC3000 - Output - SPI CLK - 12MHz max for CC3000
PIO1_21 <-- CC3000 - Input - SPI MISO
PIO1_22 --> CC3000 - Output - SPI MOSI
Are these pin strictly meant for CC3000?
Can i use them as I/O pins for my own purpose?
Can the wifi be switched off if i don't want to use this functionality?
bonitusb
Re: CC3000 Pins
Postby Carl-SolderSplash » Sun Aug 10, 2014 8:21 pm
You can use the pins if your not using the cc3000, The enable Pin obviously is dedicated
If you don't need the CC3000 module on the Wifi Dipcortex, the the DipCortex M3 has the same pinout
Users browsing this forum: Majestic-12 [Bot] and 30 guests
