PWM Control
PWM Control
Postby Carl-SolderSplash » Tue Feb 04, 2014 11:33 pm
Please refer to this page for details on how to control the DipCortex's PWM output's :
http://www.soldersplash.co.uk/guides/di ... g-a-timer/
For mbed you can use the PwmOut library, details are here :
https://mbed.org/users/mbed_official/co ... 3/PwmOut.h
NOTE : Mbed use Timer32-1 for internal timing in the mbed library, this means you can't use it for PWM's
Re: PWM Control
Postby Carl-SolderSplash » Tue Feb 04, 2014 11:36 pm
Mbed
Example code, it generates 8 PWMs :
http://mbed.org/users/SolderSplashLabs/ ... ortex-PWM/
Be aware that the default PWMout period is 20ms which is fine for a 32bit timer but will overflow the 16bit timers.
Pins that use the same timer share the same period. Match register 3 is used as the period match register, TMR32-1 is used by the mbed library, so you can't use it.
Mbed PwmOut library can use the following pins :
Timer/Match Register Pinout Options
CT16B0/MR0 p15 (P0_8) and p19 (p1_13)
CT16B0/MR1 p16 (P0_9) and p20 (p1_14)
CT16B0/MR2 p27 (P1_15) and p27 (p1_15)
CT16B1/MR0 p24 (P0_21)
CT16B1/MR1 p9 (P0_22) and p38 (P1_23)
CT32B0/MR0 p17 (P1_24) and p26 (P0_18)
CT32B0/MR1 p29 (P1_25) and p25 (P0_19)
CT32B0/MR2 p35 (P1_26)
Users browsing this forum: No registered users and 176 guests
