Creating .bin file for boot loading
Talk about our 40 Pin Dip ARM Cortex M3 / M0 Here
Postby Carl-SolderSplash » Fri Apr 19, 2013 10:33 am
By default Code Red's LPCXpresso IDE doesnt create a .bin file you can use for bootloading, but theres an easy way to get it to.
  • Right click on the project
  • Expand the "C/C++ Build" Tree
  • Select "Settings" under "C/C++ Build"
  • Select the "Build Steps" tab
  • Update the Post Build steps command with this :
    arm-none-eabi-size ${BuildArtifactFileName}; arm-none-eabi-objcopy -O binary ${BuildArtifactFileName} ${BuildArtifactFileBaseName}.bin; checksum ${BuildArtifactFileBaseName}.bin;
  • After building you should find a .bin file in your debug directory
  • With the DipCortex in bootloader mode you can drag and drop this bin file on to the removable drive and re-flash it's software
Re: Creating .bin file for boot loading
Postby Carl-SolderSplash » Wed Oct 30, 2013 11:23 am
Newest versions of LPCxpresso have the correct string in build steps, but have the bin file creation commented out. Simply remove the '#' and you will build a .bin as well as an .axf. It should look like this ...
arm-none-eabi-size "${BuildArtifactFileName}"; arm-none-eabi-objcopy -O binary "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" ; checksum -p ${TargetChip} -d "${BuildArtifactFileBaseName}.bin";
Postby donster2k » Mon Jul 14, 2014 9:54 pm
Carl-SolderSplash wrote:Newest versions of LPCxpresso have the correct string in build steps, but have the bin file creation commented out. Simply remove the '#' and you will build a .bin as well as an .axf. It should look like this ...
Thank you for sharing that! I was wondering why there was no bin file created in the LPCOpen examples.
Donal
donster2k
Postby Carl-SolderSplash » Tue Jul 15, 2014 9:45 am
Glad it was useful! :)
Return to DipCortex M3/M0
Users browsing this forum: No registered users and 1 guest
