Board dimension
Are you an eagle cad user, share your tips here
Board dimension
Postby bonitusb » Thu Jul 24, 2014 12:34 am
HI,
i want to mount my Wifi DipCortex board on a PCB.
I need to know the dimension of the board and Pin distances.
When can i obtain the mechanical drawing of the board?
Thanks
bonitusb
Re: Board dimension
Postby Carl-SolderSplash » Sat Jul 26, 2014 11:53 am
Hi replied via email as I saw that first, for others ...
The DipCortex Range are based around the idea of being able to replace 40pin DIP devices so they have the same pin spacing.
row spacing is 15.24mm and Pin to Pin spacing is 2.54mm
heres a mechcanical drawing for a typical 40pin dip : http://resource.renesas.com/lib/package ... -600a1.pdf
Our Github page here : https://github.com/SolderSplashLabs/DipCortex-Eagle
Also has a PCB module for both the DipCortex M0/M3 and WIFI with a board outline
Return to EagleCad - Hints, Tips and Tricks
Users browsing this forum: No registered users and 122 guests
